CentexMachineShop
- Jan 12, 2020
- Bastrop
Good afternoon.
Had a fairly significant crash this morn using a Ingersoll 6” 5N6J SEHT1504 45 deg face mill on a K&T 3K vertical. The forces involved were pretty incredible. Suffice to say it’s the worst crash I’ve had happen. Fortunately the mill appears to be fine, stripping the hold down t nuts and throwing a 8x10x2 block of steel across the shop. Unfortunately it totally smashed one insert pocket on this essentially brand new insert body. The question is what is the recommended practice, aside from replacing the face mill on abandoning the pocket altogether. It has 12 inserts, so would it be best to drop the insert 180 degrees from smashed pocket and then drop feed rate some to match a 10 insert mill or would you just run it with 11, still cutting some feed?
Curious to see what folks would do. I don’t think it’s repairable. Too bad as this was not a cheap tool.
