The bolt that flips the head upside down spins free and now it's stuck at a cockeyed posistion. I'm guessing that the bolt has come disconnected from the worm gear inside. With the worm gear there, I can't backdrive it vertical, and cant turn it with the bolt. So I guess I'm taking the head off. I already know it's just the 4 bolts on the front, but there's a lot of weight there. Is there a best practice for slinging the thing and jacking it up so it doesn't come crashing down when I release the bolts?
Here's a photo. It's tilted down because I was transporting it and figured that if I couldn't rotate it upside down, tilting the head down might lower the center of gravity a little. The tilt still works, so I can fix that.
