GENERALDISARRAY
- Jan 3, 2019
I was wanting to use the Supatouch optimization now that I have a machine with high speed skip.
For some reason the inspection plus disc/wizard I have will not output the O9800 supatouch program. The program does not appear in the folders on the disc either.
What are some methods of probing speed optimization without the supatouch utility? I always thought that the 9801 cal routine did some speed optimization but that is not the case.
My fast feed on all machines including the one with high speed skip is the default 2540.
As I understand it with the newer cycles Supatouch determines if you can use single touch or not.
on another similar note
should a machine with scales have the parameter on or off for servo lag skip position compensation?
