RFQ
Looking for a lead time of around 2 weeks.
Parts are all < 8" x 4"
File: Pole Bracket Sides
QTY: 2
Material: 6061
Tolerances: +/- 0.005”
Notes: 7mm holes are M8 x 1.25 tapped. Chamfers and radius are non critical and can be changed for ease of machining
File: Pole Bracket Base
QTY: 1
Material: 6061
Notes: Chamfered holes are to be countersunk for M8 Din 7991 hardware
File: Pole Bracket Plate
QTY: 1
Material: 6061
Notes:
File: Pump Insert
QTY: 4
Material: 316
Tolerances: Non Critical
Notes: 9.5mm hole is M10x1.25 tapped. None of the dimensions are critical. You can use regular 3/4” x 1/2” 316 stock, cut roughly an inch and half length for each one and drill and tap a hole.
Please email me at [email protected] for step files.
Nate
QTY: 2
Material: 6061
QTY: 1
Material: 6061
QTY: 1
Material: 6061
Notes:
File: Pump Insert
QTY: 4
Material: 316
Nate
