Rotary table, tru-trace, heat treat oven and more FS
jamie76x
Nov 26, 2011
Pittston, pa
All items located in 18640 Pittston Pennsylvania. Please obtain your own shipping quotes.
Troyke DMT-18 rotary table. 15x15 square table with x&y axis. Very impressive and heavy rotary table. Asking $400 . It's at least 500 lbs on a small skid.
Tru-trace set up. Single axis slide with stylus and pump. It's a complete set up and was used to cut cam plates with a rotary table mounted to it. Asking $250. Probably 500-600 lbs total and a full size pallet.
Heat treating oven. Runs on propane or natural gas, any adjustable venturi lets you tune the air/fuel mixture to accommodate either supply. Inside dimensions are 18" deep, 10" wide and 6" tall. Oven works well and I believe will reach 2200 degrees. Comes with a thermocouple and guage set up that i have not hooked up or tested. I'll ship it but I'd be afraid of the fire brick busting up . Probably 300 lbs and would be a normal size pallet.
Bridgeport variable speed belt housing. In good shape with no major gouges or scratches..will polish up nice. Asking $120, this can be shipped UPS.
Email directly is best. [email protected]
Big troyke rotary is sold.
The oven needs some of the fire brick replaces... 100 bucks takes it.
Make offer on trutrace.
I need to get rid of this stuff
