[email protected]
- Nov 15, 2022
Hello,
I have a Grizzly G 0602 lathe about six months old. It is mounted on the optional workbench with splash guard, leveled.
This little lathe cut great in the beginning, glass smooth cutting C1018 or stainless or bronze using either HSS or carbide.
I changed out the tool holder to a quick change system and machined the new anchor piece to a tight fit.
Some time after changing to the quick change setup, changing the gearing and moving the belt between high and low speeds i started getting a smeared and or line finish. These tiny little lines perfectly spaced on all my cuts. Also if I take more than 5 thousands i get a smeared finish, rough and ugly.
This happens when i use carbide or hss.
Everything has been tightened down and I check squareness of the tool holder by using a 1 2 3 block against the chuck then tighten it down.
My tool holder is spot on to the middle of the work, I double checked the tightness on the chuck, switched back and forth from the quick change tool holder to the original tool holder. Adjusted the jib, rechecked level, checked gear spacing, used different speeds and feeds and nothing will give me that finish i used to get.
To change my belt from low speeds to high speeds i have to loosen the motor mounts as per the manual, this is a process because the bottom nuts are pinned up against the splash guard that is secured to the table. No wrench will fit, i tried to even modify a thin wrench and no dice, with the workbench splash guard on i have to lift the lathe a bit to tighten or loosen the motor to allow the belt to be installed or removed. This being said i have to check level each time i change from high to low or the reverse.
Oh the steel i have been using is 1018 so that has stayed constant just the finish is horrible.
Any suggestions would be great, i am at a loss for what i am missing.
Thank you,
TWS
Thank you,
TWS
