I use a 60HP RPC fed from a 45KVA single phase transformer. It does well supplying power for all my CNC's and manual machines, however, it does a bad job of handling regen current.
I have a Kitamura 5X that is a 10K RPM Cat50 machine with 35HP and I've got the Fanuc spindle drive setup for global current limiting at 100 amps. If I run it on 240 volts straight from the RPC it performs great except when I stop the spindle from higher RPM's it occasionally alarms out for overvoltage. To get around that, I have it on a transformer dropping the voltage at the machine down to 225. I notice at the lower voltage the performance isn't great with 100 amps current limiting. And it still puts the voltage spike on the line if I have other equipment running.
Would it be possible to use a regen resistor bank as a load to pull the wild leg voltage back down with an IGBT maybe? Anyone ever done anything like this? I thought I heard of someone doing this awhile back, but can't find it in the search results.
Thanks!
Thanks!
