M.B. Naegle
- Feb 7, 2011
- Conroe, TX USA
All right, I'm still working with the sales-engineer who's quoting the silent chain system, but we have the sizes and dimensions all worked out and it looks like it'll be budget-able.
The new set will be a 3" and 9" (approx.) sprocket and they quoted 1" wide chain for the 5HP application, so that solves the clearance issues.
I'm doing some figuring on the guard now, which I cut out to have a 14" radius on the bottom side and a 10" radius on the top. I'm thinking to keep it simple, I'm just going to flip it around so the big end is on top covering the little motor sprocket, and the small end on the bottom will be plenty big enough for the head-stock sprocket. There's no practical reason to have the extra space up top, but mocking it up on the machine it's aesthetically nice since it matches up with the large diameter of the motor and the overall shape flows well with the head-stock and motor's "round-upon-round" design layout. It's currently 6" wide for the flat pulleys, but I can trim 2" out of the middle easily. I'm going to make a flange to locate and mount around the headstock's input shaft and then add another bracket further up, and I think it will be fairly solid with those two mountings. With these changes the collet tube will work without extensions, so that's another win. It'll still be behind the guard however, so having the extensions might still be helpful to get a better grip on the wheel.
(pictures incoming)
One other challenge is that the sales-engineer noted that these silent chains work best in an oil bath set-up. I'm waiting to hear back if the low RPM and low duty cycle of this lathe will merit manual lubrication (squirt some oil on the chain when you start it up, same as the ways and every other oil point on the machine), but if it really needs a bath, the guard is already welded shut on the edges and I can cut and weld the bottom end to be more of a tub and add some flanges and/or rubber stripping to the clam-shell seams to make it oil tight and add an oil level sight on the side. It wouldn't need to be fully submerged up to the shaft opening, just enough so the chain is pulling oil up with it. They recommended a light weight oil for it so I'm planning on using the same #10 spindle oil that's in the headstock bearings. Of course I'm going to hold making these changes until the sprockets are on the machine.
(pictures incoming)
