Tungsten808
- Sep 9, 2021
I had the battery go dead in my machine and I have gone through and set the Parameter 1815 APZ to clear the alarms for X Y and Z. I was preparing to carry out the procedure to reset the tool change height when I got this alarm upon trying to REF Return the machine.
PS0302 Setting reference position without DOG is not performed
I have never ran into this alarm before. Prior to resetting the APZ settings I manually went through and unloaded the tools from the side door, not sure if this affected this parameter.
Problems I had in the past with the tool changer was also a Chip was stuck to the Proximity sensor and I checked that an appears to clear and changes state from red to green, currently in a red indicator state with no tools loaded in the magazine.
I did a search on the form and appears a member also had the same issue but I did not see the solution in the thread.
Much thanks in advance.
