DubbleTrubble
- Feb 8, 2021
- Hollyweird CA
I've contacted Haas, but they don't service machines this old, nor carry parts or even info, and couldn't help me other than to provide the info below and recommend that I find an aftermarket solution.I think your parameter reasoning is correct, home on both Z channel and table zero switch and inverted Z.
I do not have one of those controls. I presume it rotates backward to find the table zero switch then rotates forward until the next Z index.
Unless you can change the parameter the new encoder will have to have the same Z polarity.
1/2" shaft might be hard to find, most are smaller. I had to turn down the motor shaft to put the encoder on.
"This is the description I have for the encoder on the motor. It is all together as 1 unit."
I'm finding a few companies making replacement Renco encoders. I will contact one of the encoder manufacturers tomorrow.
In looking at old posts from Magno-grail, I see he's encountered something like this quite a few times and there are some solutions out there, which makes me hopeful.
