I got a cheap slip roller from Amazon. 24inch for $300... wasn't expecting much.. seems to work OK... ish...
I have 15 to 20 thousandths gap between the 2 main rollers in the middle when the bottom roller raised all the way up. The gap goes to 0 near the ends of the rollers on both sides. The gap is only present during certain rotational position of the rollers and goes away/decreases at other position (rotation of the roller)
My question is: Is this something i should try to even out or just leave it be? Not sure how much center gap is reasonable for 24" roller. I suspect I'll have to grind/polish the rollers to be more true round and centered to fix it.
Thanks
Thanks
