I'm face milling 416 steel with a 16k spindle Brother (no BBT) and need a recommendation for a face mill. Taking off about .04" total. Presently I'm just using a 3/8 4 flute endmill, which works fine but it takes more time than I like, and to get a usable surface finish I have to rough leaving .005 and then come back over it to finish.
Details:
I need something with a relatively square shoulder to clear the fixture. .03" corner radius max.
I'm hoping for something pretty small, because the 16k spindle doesn't have a ton of guts down low, and the standard 30 taper isn't all that rigid. Ideally something like a 1" diameter with three or four inserts.
I need a decent surface finish, but it gets hardened, tumbled and then bead blasted after machining, so it doesn't need to be a mirror.
Prefer something where the inserts are cost effective, either due to long insert life or cheap inserts. This is a long running job so saving ten cents a part in inserts adds up.
416 is a very free machining grade, it cuts as easily as 303, if not easier.
Thanks for any recommendations!
Details:
