I'm doing a restoration of what I presume is a 117C 16x36 lathe (I sent the serial code to Grizzly, maybe they will clarify that). Every part is there, except the original motor. One of the way is slightly worn, so I guess the previous owner hasn't oiled it in a while. Other than that, everything seem fine. However I need to get it running asap, and I was planning to immediately fix the spindle, the underneath motor assembly and the carriage.
I wanted to know three things related to the restoration and a few thing related to possible modifications:
-If I was to neglect the underneath motor, could it lead to permanent damage of the parts, should the bearing be worn? I do not have the mean to take the upper half of the lathe off and I would prefer not have to crawl onto the floor to disassemble, only to spend hour crawling on the floor to reassemble it, if I can even remove them since there is very little space for that.
-What grease does it take for the spindle cone assembly? The lubrification chart recommend to check the manual, but these weren't built as sturdy as these lathe, so I don't have one.
-Can the compound rest screw be replaced with an homemade one, or is it too precise of a piece for an old lathe? There isn't any dials on the saddle wheel. That probably lead the previous owner to use the compound rest to to the heavy work. That lead to a situation where there is a huge backslash onto the compound, but very little backslash while moving the entire carriage. I'm planning to get a DRO on this thing, but I'd rather not install one for this movement.
As for the modifications:
-I'm planning on getting the spindle spin around 3000 rpm, about the triple of what the lathe was built for. Would the current frictionless bearing allow such as speed without damaging the original or hard to replace parts? I don't want to be the morron putting this machine in the grave after a stupid mistake, so I will figure out if it's not safe.
