South bend motor wires have some labels missing from the wiring.
I did an ohm check and get an ohm readings on 2 sets of 3 wires. Tested the ohms against other wires and I get 0. 1 set of wires is higher ohm then the other. I assume this is a high/low.
Which is high and which low? The higher ohm set would be high?
