rimcanyon
- Sep 28, 2002
- Salinas, CA USA
I'm grinding valve seats dry with aluminum oxide stones and I don't see a lot of sparking, although the stone is in contact with the steel and it grinds and the seats look nice. Is the lack of spark an indication the stone needs to be dressed more? I have been dressing the stones every second seat; maybe I need to do it more often. The problem I am running into is slow cutting and I find it takes forever to grind out the high spots on the final cut. The stone turns at 10000 rpm. The grinder is an eccentric grinder, so it makes contact with a single point on the circumference of the seat. The contact point rotates around the seat at 20 rpm, and I usually let it go around 12 times on the final cut (36 seconds), but I am still finding high spots (.001" variation). The seats all get a 30 and 60 degree grind prior to the 45 degree cut. Often the bore of the new guide does not align with the original seat and prior grind, so the 30/60 grinds are quite important to get the seat centered, but even so, the 45 grind has to grind the high side down until the seat is even. That is the issue, it is taking forever.
All I know about the seats is that they are "hard steel", which Porsche changed over to from brass seats in 1960. So I am considering two things, wanted opinions. One is dressing more often. Second is using silicon carbide stones. The grinder mfr. made three types of stones: brown (unknown) for cast iron, grey silicon carbide for "hard seats", and white aluminum oxide for stellite seats. I have been using the aluminum oxide because I have found in other kinds of grinding, it does not overheat the work, while I have had problems with silicon carbide burning steel. So I tend to be cautious.
