CaptainNemo
- Nov 12, 2022
Hello All,
I have a Jhead round rod mill from the 40's. It was working fine, but now it seems there is no connection between the spindle and the motor. I went to remove the tooling in the collet and at first it was hard to turn, but then it would just spin, even with the brake engaged. It seems the brake is working, because I can manually turn the pulleys with it off, but not with it engaged. The motor spins freely, but there is no turning of the spindle. I've tried in main and back gears, but there is no difference. It looks like I am going to have to take the head apart, but before I do, I wanted to ask if there were any thoughts on the most likely cause of the problem.
Thank you,
Thank you,
