Milling man
- Aug 6, 2021
- Moscow, Russia
You're right, spindle grinding on a milling machine; and at the factory - on a grinding machine, they are not very different - but only at first glanceThey had a fixture with a quill set to the taper angle, and the quill moved in and out as the spindle was rotating at a slow rpm.
I assume most or all traveling spindle grinders do this?
To obtain a cone, it is necessary to combine two movements - rotation and linear movement. The accuracy of the cone will depend on how accurate these movements will be, as well as on several other features of the technology.
We'll hire from moving in a straight line. All of us, probably, have seen videos and photos of devices for grinding a cone on a machine many times on the Internet. Often this is some kind of linear motion unit mounted on an inclined or rotary table from a grinding machine - to rotate the linear path to the desired angle. As a rule, ball or roller guides are installed in such units. The length of the guides is quite short - hardly more than 40 inches. And now let's look at a high-precision grinding machine (I think that at a spindle manufacturing plant, final grinding is unlikely to be done on ordinary precision machines) - the movement of the part relative to the spindle is carried out on hydrostatic or aerostatic guides, which have an order of magnitude higher accuracy than ball or roller guides.
Now let's take a closer look at the rotation of the spindle. In a milling machine, it most likely rotates in ball bearings of ABEC7 accuracy class (I rarely met ABEC9 bearings in spindles, only in high-speed spindles), when on a grinding machine the rotation will be either in a spindle on hydrostatic bearings, or in a steady rest with sliding bearings, which at low rotation speed will provide higher rotation accuracy.
The grinding spindle of a high-precision grinding machine and the electro-spindle, usually used in portable grinding devices - I think it would be silly to even compare them
In addition to all of the above, do not forget that the grinding machine will be processed with coolant, which is much better than dry processing. Moreover, the coolant will not just be poured from a bottle, but will be filtered from metal particles and grinding material, and flow in a significant stream.
Therefore, we need to understand that grinding the spindle on the machine itself, where it is installed, is still not at all the same as processing on a grinding machine. But as LocherInc rightly pointed out above, there are new machine specifications and there is the real world And in this real world there are spindles that are not so lucky - and almost any grinding will make them better than they are.
In the lab where I work, there are two machines in which the students did not correctly fix the mandrels in the spindle, and they flew out during work. I would not hesitate to grind these spindles at least somehow and with something, rather than leave everything as it is.
