SLK001
- Feb 8, 2015
- Coral Springs, FL USA
A lot of people will spin on a chuck when it is "a little gritty". A stuck chuck can be an expensive lesson in always keeping a chuck's backplate and the spindle's thread meticulously clean when spinning on a chuck. I keep a toothbrush on hand to always sweep the threads on both. If you recently cut something like cast iron, expect to have to dismantle your chuck to thoroughly clean the swarf out of the scroll, or it will continually drop out onto the spindle threads as you try to spin it on.
I also use a parchment paper washer between the chuck and the shoulder to prevent the chuck from becoming "one" with the spindle. Parchment paper is coated with silicone, which makes it non-stick and super slick. It also is very thin, so you still get a good register. Wax paper also works here and is coated with paraffin wax.
