greenlinux
- Jan 3, 2023
Hi All,
I would appreciate any information on the following: a collet on a relatively small milling machine has eccentric ring in the threaded part that holds the collet captive (suggestive of ER) but, the diameter of the set of collets is 24mm (23.94mm) and the length of the collets are 45mm (45.07mm). It looks like ER or OZ but I have not found any standard that matches this aspect ratio. I would like to identify it as I have some sizes of collet missing and would like to source them. If it proves impossible to identify I will replace the chuck with ER and buy a set of collets.
Many thanks,
James
Many thanks,
James
