Mark Rand's suggestion of Andmar.co.uk To contact and tell them what kind of surface grinding you intend to do might be the best choice. Even if you don't buy from them likey they will give valuable information.
Automatic feeds and, down-feed to size can be very handy, on the other hand often a grinder hand can manually run a part faster than a machine can be programmed. Good to really think about what you intend to do with this machine.
You may be top grinding for size and surface finish, grinding edge bevels on parts, grinding flats and whistle flats in tool shanks, grinding step heights on parts, cut-off carbide parts, grinding flat forms, grinding to square-up sides, grinding dovetails or angles, grinding a radius on a part. Just for a few options, who knows. Perhaps just want a Surface grinder because most shops have/need them.
To be good a SG should grind near-zero flatness for the length of the chuck.
Considering a used machine it might be good to pay for an inspection,
Re; don't let a green guy try to grind that chuck.
