rons
- Mar 5, 2009
- California, USA
So I mostly use brazed carbide bits for roughing out SS or anything else. Some of them are marked C5.
And I have Iscar brand inserts for the lathe and try to save those for the finish.
Somebody said to me once that a carbide edge can start out real sharp and then quickly becomes an intermediate sharpness and stays that way for a long time.
And that HSS will stay real sharp longer in the beginning phase of use but then dulls out and becomes unusable.
This was concerning wood planer or jointer blades but it should apply to metal.
True or False?
I'm grinding the carbides and they can withstand red hot. As long as they don't get dunked in water.
So my work never gets them red hot or chips that are blue.
Will a intermediate sharp carbide edge eventually chip at some lifespan hours? Would intermittent use prolong the hours? Pecking?
True or False?
I use a diamond stone to true up these brazed carbide bits and what I notice is that if I dress them more often the chipping goes down.
When a break occurs I have to grind out more of the edge than if I periodically sharpened the edge.
Is there a formula for this?
Another issue is hand cranking. Starting on a uneven surface allows me to feel the vibrations on the crank handle.
Does a smooth CNC motion save cutting bits versus a human?
True or False?
True or False?
