I generally leave a good .005" on a side for parts of this size. Check and straighten to less than that after heat treat, and that'll leave you a little room to get the taper out of the grinder before you get to finish size.Leave a few thousands for finish grind on the bearing surfaces and ID grind the bore. Hard turning is also an option.
On the bore, if he's gas carburizing, which is the most common ? Plug up the far end and good chance it won't get much of a case at all. Or maybe even none. You'd be working with about 40 Rc then. Long deep holes like that don't get much circulation, that's where salt bath does a much nicer job. But few places do that anymore because it's poisonous and dangerous.
He's not going to do this anyhow, but just for the record
Both exist. Carbo-nitriding is sort of a combination, it has the same distortion liability as straight carburizing, I guess gives a slightly better case but ... Nitriding, on the other hand, is a much lower-temp process, gives a harder case but much thinner. It's also pickier about the alloy, results vary widely depending on material. But yeah, a lot less distortion - to the point of none. You wouldn't grind a nitrided part. It's not quench and temper so has to go on *over* an already-heat-treated part, otherwise the hard thin case will spall off if there's much load. Maybe would not be a problem here but we're doing theoretical now, OP has decided to go another wayIf I was carburizing then I’d leave .01” per side on a shaft that long and skinny. I was talking about is nitriding or I think I’ve also heard it called carbo nitriding. From what I know it happens at lower temps and has less distortion
That's not a half-bad idea, actually. With the gun forum here someone should have a good source for getting it done reasonably.Another option might be ... melonite.
Here are a couple pictures of the bearings. I whittled a little on a corner and think they're soft enough, so unhardened 1018 could be an option. As I noted before, my only concern with that would be how the tool taper holds up.
looks like a 235 chevy head setting in the back ground
Notice
