Kentuckydiesel
- Feb 4, 2011
- Kentucky, USA
I found this site a couple days ago and have been enjoying reading all the past posts. Definitely a good knowledge base here.
...So after going through a bunch of posts, I would like to get some thoughts, advice, opinions, or even a go to hell regarding my current situation.
I recently got hired back to the family company as plant manager. This company means a lot to me as it was started in the 1880s by my great-great-great-grandfather, making me 6th generation there. While this is a great thing, I definitely have a tough road ahead.
Our company was booming until the mid-late 1980s. A couple hundred employees on a couple shifts, engineering, drafting, R&D, machining, etc were all done in house and filled our 160,000sqft of manufacturing facility to the brim. Since then, we have dropped a couple product lines and as a bunch of guys have retired in the past couple years, we are actually down to 4 employees in the factory, myself as the plant manager, our office manager, and one of my uncles who is President.
No more are the days when a factory employee just cranked out parts...we have become more of a low volume, high end fabrication shop. The company is actually doing okay on our currently products, but we really need to branch out/expand in order to survive in the future. In the long run, I would like to develop new product lines and upgrade equipment...but until our cash flow is strong enough, I am hoping to figure out the best way to fully utilize the equipment we have.
Here's where things get interesting:
With exception of our late 1970s Welty-Way Slear/decoil line and a couple lockformers of the same era, pretty much all our equipment was made between 1912 and 1945.
We have 31 presses from 12-350tons, 5 press brakes up to 190tons, 4 shears handling up to 1/4" mild steel, an assortment of sheet metal rollers, bending rolls, spot welders, metal saws, overhaed cranes, and a fully outfitted welding shop with DC Stick, Mig, Tig welding plus plasma cutting, and oxy-acetylene cutting ability. Although all of the above get used on at least a semi regular basis, there is one section of our company that does barely more than collect dust....our machine shop.
In the machine shop we have some great old WWII era equipment with every accessory and piece of tooling that 1945 could possibly offer. Unfortunately when our last machinist retired, there just wasn't enough in-house need to hire someone else to take his place. After reading about what some people on here are doing with older manual equipment, I'm left wondering if it wouldn't be worthwhile to put ours back to work. So you guys have a good idea of the setup, here is a list of our machines:
-Walker-Turner Utility Drill Press
-Cincinatti-Bickford Super Service-Radial Arm Drill
-Cincinatti-Bickford Super Service-Jig Boring Machine
-Avey Drilling Machine Co.-2-B Production Drill
-Carlton-Radial Arm Drill
-South Bend Lathe Works-8"x36"-15-YA
-Springfield-23"x96"-Engine Lathe
-Springfield-20"x110"-Engine Lathe
-Warner and Swasey 16" turret lathe with Lynn Hydro Drive
-Hendey Machine Co.-14"x60"-Toolroom Lathe
-Cincinatti-#4-Horizontal Milling Machine
-Kearney & Trecker-#2-Model H Milling Machine
-Pratt & Whitney-3C-Bench Miller
-Brown & Sharpe-#2-Cylindrical Grinder
-Blanchard-#18-Rotary Grinder
-Brown & Sharpe-#5-Surface Grinder
-Cincinatti-#2-Tool Cutter/Grinder
-Jones & Lamson-Chaser Sharpening Machine
-Blake-#2-Tap Chamfer Grinder
-Dumore-Drill Grinder
-Porter-Cable-B68-Wet-Dry Vertical Belt Grinder
-Standard Electric Tool-24VA-Vertical Spindle Sander
-U.S. Electrical Tool-500-Bench Grinder
-Electro Machines-M687-Bench Grinder
-Peerless-Horizontal Hack Saw
I may be forgetting something, but that should be the majority of them.
So given the machines, I feel like we would be capable of handling all sorts of small-run parts/part repairs. Would you guys agree? If so, how difficult is it these days to find a machinist that doesn't require a computer to translate his intentions to the work? Unfortunately I'm no expert in the machine shop area. I can do enough to recreate/repair parts, but that's about it. I would basically need to find someone who could come in, sort through drawers and cabinets full of tooling and whatnot, and know how to put it all to work. Am I imagining the impossible here? Would it even be worthwhile to do any more than piddle until I learn more myself?
Thanks,
Phillip
Thanks,
Phillip
