Tig welder coolant
MC Parts Kid
Aug 27, 2014
Hoboken NJ
I'm doing maintenace on my Miller Syncrowave 250. I want to change the coolant. Miller wants $56 clams a gallon and most places will only sell a box of four. Anybody here have an alternative? Thanks, Bob L
I've been using this in my welder for a few years after I needed to keep it in an unheated space:
Much cheaper than the Miller coolant. I haven't had any ill effects from it.
I used distilled water and it turned brown. Found that there were two fittings in the coolant system that were rusting.
Made copies from some 304SS. If I had been changing Miller coolant every 6 months I would have never seen this.
I left distilled water in the system. It's a bad design when a pressed in barrel starts to rust. Might even pop out of the hole.
Sitting above the enormous machine transformer.
dont use automotive coolant!,
worst case they all say to run straight water unless you get into freezing temperatures, then you add coolant.
around here its about $20-30 a 1 gal jug, still made from glycol, just not the ethelene type, more or less food grade chiller coolant.
all welding places can get it.
I wouldn't run straight water...I'd always want some sort of anti-corrosion agent in there. I also suspect the goo-goo helps the pump stay at least a little lubricated.
I think we're currently using Profax 70/30 blend (ethylene glycol) coolant in our TIG cooler. I know we've also used propylene glycol in the past and still have a few jugs of it on the shelf. Can't recal what brand or where we got it as it's in un-branded jugs.
