Tips in general, little discussion , just the tips,
michiganbuck
Jun 28, 2012
Mt Clemens, Michigan 48035
Tip one: a good smear of grease on the tap flutes will hold/retain most of the tapping chips
Tip two: Zip-lock bags Sharpy marked make a decent small or any parts for OK safe storage.
Tip three: Hold your scale on an angle, or straight edge and look past to something straight or horizontal to roughly line up a part.
Mcfish
Aug 17, 2020
Similar to your third tip, but when setting up a vice on the mill: use your eyes to line up the back of the vice with a t-slot or the back edge of the table. This is usually sufficient to get the vice within a few thou.
I had a coworker who I had a competition with doing this. Who could be the straightest on the first indicator sweep.
Jan 15, 2005
The Netherlands
If a bolt is stuck hit it with a hammer on the head a few times
If a allen bolt is stuck and turned over also hit it with a hammer The hitting helps to loosen the bolt but also reduces the hexhole slightly
If something is stuck on a shaft also hit it with a hammer all around to strech it (within reason) If the setup is not sturdy the hammer gets no impact Then hold a heavy piece of metal opposite the impact area
If a thread is damages a bit and turns heavy turn the nut on till it is going heavy Then tap(not hit) it with a hammer while applying rotational force Work along till the threads fits properly
If a strip is not straight hit it with a hammer on the inside curve while laying on a anvil of some sort
Peter
Apr 19, 2006
Manchester, England
If you ever find yourself in a situation were you need to tighten a nut and an hexagonal bolt but you can’t get easy access to the bolt head. - Give the inside edge of one of the corners of the bolt head a sharp tap with your hammer. This will create a small, sharp, spike on the inside face of the bolt head. That small spike will dig into whatever you’re fastening and prevent the bolt head from turning.
Regards Tyrone.
technocrat
Feb 9, 2009
Oz
When your pipe thread is good and the teflon thread tape is too slippery to hold on, put a few dings in the thread with a hammer, wrench, another thread or whatever is handy. This will catch the tape and hold it so you can wind it on. Great will brass all-thread.
Apr 19, 2006
Manchester, England
Following on from your post - there is a right way and a wrong way to wrap the tape around the thread. Holding the pipe in your left hand and the tape roll in your right hand place the loose end of the tape on top of the thread and hold it in place with your left hand thumb. The tape needs to come from the bottom of the role . Wrap the tape over the top of the thread and then round the pipe. Easy to do, hard to describe.
3 wraps of the tape is usually enough.
Regards Tyrone.
Apr 19, 2006
Manchester, England
If you’re making a gasket to go between two bolted pipe flanges avoid the temptation to cut the OD of the gasket round right away. Leave a corner on the gasket material. It will help you orientate the gasket bolt holes between the flanges. Especially if the gasket is slippery with sealing compound. Cut the corner off with a sharp knife when you’re happy that the flanges are bolted up correctly.
Regards Tyrone.
