Hello! I'm a first-time poster here. The High School I work at has a Tongtai VTX-7 Vertical Tapping Center with a Mits M80 controller. I started getting a couple of alarms last night and am having trouble figuring out how to clear them'*. The two alarms are:
1068 LUB. PRESSSURE FAT.
1040 LUBRICATION ALARM
The CHIBA (MFE-302FW-T3P) lubrication pump attempts to pump way oil but instead of turning off in about 5s like it normally does, it continues to run for about 30sec until the machine turns it off and shows the alarm. If I reset the controller it does the same cycle and the displays the alarm. I haven't changed anything on my end. The pump has plenty of oil in it but it seems like the pump isn't building up enough pressure. Is there an adjustment or switch I need to check?
The VTX-7 is a really nice machine but the problem is lack of support. There are essentially no online resources to help guide troubleshooting. I'm hoping someone here has the experience to help me troubleshoot this.
Also, We're located in San Jose CA and if there is a technician that see this or if someone knows a local technician that can come troubleshoot this in person we are willing pay to bring in someone to help.
Thanks!
Thanks!
