thunderskunk
- Nov 13, 2018
- Middle-of-nowhere
Hey!
Some silly questions about milling tool steels like 1060, 1045, A6, and S7:
- Generally, what’s the benefit of going to a larger diameter endmill?
- Scenario is: we mill an outside profile with a 1/2” endmill on a BT40 Fadal that has the clearance to accommodate 1-1/2”. Tool life is 32 parts. Would increasing diameter increase life? Chip clearance? Cycle time?
- What’s the intent of coolant when machining steel? Are we trying to cool the tool, the chip, or the workpiece? How important is having the right oil/water mixture?
- How do folks machine steel without coolant?
- Is dry machining steel sensitive to bad runout?
- We grind all surfaces by hand just for a surface finish with super loose tolerances. What’s out there for mill tooling with grinding/polishing faces?
- What’s the benefit of using roughing endmill with serrations? I’ve used them before, but I’m trying to convince someone else to try it.
