learning80
- May 10, 2018
I'm looking at acquiring a TOS BPH20-NA surface grinder, that has a bit of wear, to use in the short term and in the long term rescrape or regrind to bring back to very accurate levels. Is this a good idea?
These videos, of the same model, shows the way configuration -
My question is how do I tackle the ways, which look to be inserts, and are most likely hardened. I am guessing they were ground in place on the machine (though I'm hoping this is not the case) and thus you cannot remove them, regrind them, and then reattach them. If you could life would be a lot easier, I could just do this and take them all to a machine shop.
For the table could you put it upside down on a surface plate and check / scrape the ways when it is on there? I did this with another table and it worked well, so long as the scraping wasn't too heavy, but the item being scraped is, and it doesn't move around much. However I have no scraped in ways designed for cylindrical rollers. Or perhaps I should take it to a machine shop, though at a 1800mm table, I'm not even sure there are many or any shops in my area capable of regrinding it along its length.
Thanks for any assistance / advice.
