Stirling
- Dec 11, 2013
- Alberta canada
just picked up a auction TR-110 at auction (rolled the dice I hope it works!)
anywhoo
I got a job I need 5 axis positioning on and have no 5th experience/expectation or capability. how hard can i push something like this before overcoming its limited break tourque? (40lb) Rotory spec sheet ( http://www.vanwaasdijk.com/assets/datasheet/DAT_TR110_UK.pdf )
obviously theres alot of factors when overhug drilling and such.
my highest load cut would be to drill a 3/8" holes in 4140htsr overhung 7" from B 2.5" from A (see photo) in a 5 axis position
i will also be drilling a 0.5" hole on top of the small rounds in the fixture, but being at 90deg b i can toss a tailstock into it if needed.
im all ears on advice in this situaion and with any/all advice you have with regards to this particular oddball haas rotory or any other 5 axis stuff love ot learn!
jobs not a panic at all and if this trunnion does not work out ive got a hrt160 and hrt210 i can work together into a 5th anis (trunnion on the 210 with the 160 bolted on, not alt of working space with this one tho, but enough for this job if needed)
anywhoo
