DanP_85
- May 24, 2008
- Taupo, New Zealand
Greetings. So I have a Chevalier FTC-1320v VMC that I bought about a year ago. Its about a 2005 vintage, BT30 VMC machine with Oi-Mc control and a rotating table (similar to a Brother R450x1). On the chevalier machine the table is the 4th axis.
I'm finally getting around to getting it setup. This weekend I was flushing the coolant sump with CimClean cleaner and then loading new coolant, and I got a black screen of death with Alarm 926, which is some problem in the FSSB communications. Screenshots below.
There is not a good fibre optics drawing with this machine but I think the fibre network goes from the PLC to the 4th axis servo amp then the SVPM last (XY and Z all being part of the single svpm box if I'm understanding correctly?).
I was able reboot the machine but had Alarm 5136: FSSB Number of Amps is Small, which means that the PLC sees less servo amplifiers than it expects. This went away after a few minutes and i was able to reset and home the machine. I've had the same fault repeat about 4-5 times, usually after about 10 min of run time, and the last few times it has rebooted just fine without the 5136 alarm.
The interesting thing is that if I'm reading the manual correctly, the first screenshot of alarms indicates it happened in the 3rd module in the fibre chain, but the others indicate 0 or the PLC itself.
1. Am I interpreting the codes correctly?
2. Does the other info on the screen mean anything helpful that might narrow down my search?
3. If so what are my next best things to check? The Fanuc book is a bit unhelpful, basically says its either the fiber cable, any module up or downstream of the error code location, a pulse coder power fault or a power supply in general....pretty much every piece of the machine.
4. I disconnected the two fibre cables (PLC to 4th) and checked them with flashlights, they seemed ok but is it worth replacing these? I know some fibre optic techs, could see if they could check them I guess for a lot of beers/money, there is a short one between the 4th and SVPM, but the main one is buried in the machine from the back cabinet to the control panel.
I have manuals and wiring diagrams for the machine, can share if it helps.
Parts Details:
Oi-MC A02B-0309-B502
Servo amplifier Bisv 20 A06B-6130-H002 E
SVPM3-15i/A part # A06B6134H303#A
Things to note:
All axis were stationary when it occurred
Spindle was off
Coolant pumps were either on or off
No program was running
Parts Details:
Things to note:
Spindle was off
