Is the table locked? That lever does in fact release the table and allow direct indexing. You also have to release the worm gear for that to happen which frees the table up so you can turn the entire chuck by hand. There is most likely a masking plate at the bottom of the unit which can be changed for varying division direct indexing.I've tried operating the lever while rotating and nothing changes. The lever only moves about 30 degrees and springs back when you let go.
I'm not sure how exactly that would work... I'll take a picture of the bottom of the unit tomorrow but I don't think there is anywhere a plate could be installed on the bottom. Also I'm not sure how you would disengage the worm gear. The small t handle above the main knob doesn't appear to do anything. The large handle is the brake to prevent the unit from turning.Is the table locked? That lever does in fact release the table and allow direct indexing. You also have to release the worm gear for that to happen which frees the table up so you can turn the entire chuck by hand. There is most likely a masking plate at the bottom of the unit which can be changed for varying division direct indexing.
Under the base, there should be a plate held in by 2 screws. You remove that plate and it exposes the masking plate if one is installed. Different masking plates provide various direct indexing. As far as releasing the worm gear, there should be a knurled ring near the crank and dial, turning that (I forgot which direction) should release the worm. The crank will no longer turn the table but the chuck can then be turned by hand after moving the release lever. I hope that makes sense... Also, be sure you don't have the table locked which is what the lever with the black knob is.I'm not sure how exactly that would work... I'll take a picture of the bottom of the unit tomorrow but I don't think there is anywhere a plate could be installed on the bottom. Also I'm not sure how you would disengage the worm gear. The small t handle above the main knob doesn't appear to do anything. The large handle is the brake to prevent the unit from turning.
Also when you move the lever that is circled in the picture, the adjusting bold with the jam nut under it moves slightly. Almost like it's an adjustable stop of some kind.
Notice
