Peroni
- May 18, 2007
- Yadkinville, NC
I'm trying to vapor polish some polycarbonate sight glass windows without much success. I've got the methylene chloride, a hot plate, flask plus all the proper PPE recommended for working with this particular chemical.
The part is 3/16 thick with a pocket in one side so the actual "sight" portion of the disk is 1/16 thick. It's the floor of that pocket I need to make optically clear. The other side didn't get machined so it's still clear and the outer edge does not matter.
I've tried dipping the part which worked great for a few seconds before drying to a cloudy finish. I first tried vapor polishing in a beaker but all that happened was the part melted and again turned cloudy when dry. Next I tried a flask and directed the vapor to the surface I wanted to polish and nothing happened to it. The edges of the pocket got polished and rounded over but the actual surface I wanted to polish didn't change. Parts were cleaned with soap and water several times with a final DU water rise and handled with gloves. Material was certified US made from Piedmont Plastics. What in the world am I doing wrong? I really wanted to do this in house vs sending the job out esp as I've only a couple parts.
