We just commissioned a new to us 2007(maybe 08?) VF3SS. Haas techs were in yesterday adding probing and breaking in a new spindle. We mounted our fixturing this morning and were hoping to take some test cuts but out of the blue the side mount ATC stopped working with an Alarm 626; the pocket swings down, but then the tool change halts and throws the alarm.
We can manually trigger the solenoid and the pocket swings up and down fine so its not the valve, or the actuator. We then checked the diagnostics page and the Pocket Down bit is always reading 0 while the Up bit switches when the pocket is moved, so the "Down" sensor must not be functioning. We took a few panels off but cannot figure out how to access that switch without removing a lot of hardware. The Haas video I found is definitely not the same ATC we have because the sensors look readily accessible.
I am hoping somebody out there has a secret shortcut to accessing the sensor that reads the actuator position!
