rons
- Mar 5, 2009
- California, USA
That would work. Someday after you buy it you may look inside and say "I could have built this, why did I buy it?"
Save yourself the trouble and build it now.
With regard to the previous question, you can't just pull a 115 leg off of the output of a VFD (I don't know the specific technical details, but I don't think there's a true 115 volt leg to ground available, and the VFD does various monitoring of the single output; i recall reading the reasons long ago but have forgotten). And wiring separately from an available 115 source with a VFD would require rewiring/reconfiguring of the controls on the lathe. So usually, people only pursue that in the event they want to replace the 3p motor altoghether, or the electrials have been modified already. Also, in the HLVH lathes, the spindle motor is a specially balanced behemoth for its HP, and may also be in the DSM. Again, the RPC is plug and play if controls haven't been compromised.That would work. Someday after you buy it you may look inside and say "I could have built this, why did I buy it?"
3 phase uses no capacitors. It is self-starting.I have a Doerr 3N229D 5hp 230/460V 3ph motor.
It has no capacitors mounted on it.
It does not say "Induction" on it......how do I tell if it is or not?
Notice
