hend.engineering
- Jul 30, 2019
Hi,
It's been an issue probably since I bought the machine 3 years ago but has only come to light as I've tried to be more ambitious with it.
Esentially, 20mm end mill, 36mm DOC 2mm width of cut, 4FL in steel. 250m/min Vc 4000rpm, 2.8m/min cutting speed. Mild cutting data for what the tool is capable of.
I set up a rectangular block of mild steel in the Kurt vice to test, vice aligned to X, so jaws along Y.
Cuts quietly in Y, sings like a long overhanging boring bar when cutting in X.
Noise reduces with RPM and feed override as you might expect.
My assumption is that it's worn linear guides, am I barking up the right tree?
Some head nod / wiggle perhaps.
The longer story is that I had a pair of guys around from ZCC cutting tools who have been happy enough to let me have and test a few of their cutters. We went at it and although it started well, and the cutter put up with it admirably, the noise in the X direction was deafening. We slowed it down but basically the only way it worked was with a 1/4 of the tools cutting capability.
