Jim Moser
- Sep 5, 2004
- Santa Cruz Ca.
Just started making a stub shaft or PTO to mount off the front of crankshaft on a marine Volvo diesel, I've built a few before for other engines but this one has an odd bolt hole pattern, don't. Know why they wouldn't use equally spaced pattern? Also tried to get 1/2 inch longer bolts but they seem to be 11mm by 1.5 pitch, not readably avaliable at McMaster or other searches? This is basically a shaft welded to a 1/2 inch plate trued up to run a double A pully for a small hydraulic pump. Extra pulleys don't seem to be avaliable for this engine like other brands. Don't know much about Volvo's or odd metrics.
Maybe Volvo doesn't want any side load taken off the front of crank.
My old Isuzu has been running 5 B belts like this for 30 plus years 24 gallon hyd. Pump and 7 hp reefer compressor with no problems.
Any ideas
Thanks. Jim
Any ideas
Thanks. Jim
