Wanted: SB Heavy 10 apron rack pinion gear/shaft
Gitman
Jun 26, 2023
I am looking for the part labeled #32 in the attached diagram. It is for a 1977 10L. Any leads would be greatly appreciated!
I can be reached here: [email protected]
Curious if your pinion gear was marked? Usually on the end it has a stamping as to size. P20 (Plus .020) or M10 (Minus .010) or STD. etc.
I went looking for a replacement during a complete rebuild and it was scarcer than hens teeth. Never found one (That wasn't worn out).
My gears look about the same as yours, I am going to adjust the fit of my used gears by installing bushings for the shaft and shim under the rack. There is a number on the end of mine, I did not realize t was a size so thanks for that.
The letter "S" is stamped on the end of the shaft. I assume that means standard.
