A question for you metallurgists...
I have a cheap manual Sieg micro milling machine made with a fairly soft cast-iron steel, easy to cut and machine with HSS bits. Two 6.0x1.0 mm holes were easily drilled and tapped into the vertical column to which I mounted a custom designed aluminum adapter for a CNC stepper motor upgrade.
Unfortunately, I drilled the holes slightly out of alignment. My plan to fix the mis-aligned holes was to weld them closed using E71t-gs flux-cored wire and grind/file the surface flat so that I could start with fresh new holes in proper alignment.
Welding the holes went without a problem and the excess weld was ground flush with the column using a electric grinder. However, I noticed that when I dragged a new file across the surface, the file WOULD NOT cut into the weld material. I then tried to drill the weld material with a HSS drill bit and found that the drill would not cut into the weld. It wouldn't even scratch the weld!
For some reason, the weld became INSANELY hard and I am unable to machine the weld. I can still file and cut the metal surrounding the welds, but I cannot machine the weld that was filled with E71t-gs wire. Looking at the manufacturer's description of E71t-gs, it states that it is a general all purpose wire for mild steel, including galvanized and sheet metal...
Can someone please tell me what happened and why I cannot machine the repaired metal? If I have to grind the material out again, can someone please tell me how to make a proper weld that more closely approximates the metal composition of the original cast iron material? Will brazing the holes be better in this case? Thanks in advance...
