Im getting gullet cracks in my blade and trying to determine the best tension to prevent this. Seems to be a large range of numbers out there. There are alot of places online recommending 15,000 PSI, some as low as 12,000 PSI. Lenox recommends up to 30,000 PSI. And our saw at work (Hyd mech S-20, no issues on this one) recommends 1000-1200 kg wheel tension on a 1" blade which works out to around 38,000 PSI. This saw works fine at that tension.
My saw at my home shop is causing the problem. It has a terrible system for tension so i normally just tighten it till it feels about right. Id like to find a better way of tensioning blades but I dont even know what force i should be aiming for. Wondering what you guys run and reccomend.
Knowing that the saw at work is working well with alot of tension and lenox reccomends up to 30,000 should i just aim for 30,000 PSI?
