EPAIII
- Nov 23, 2003
- Beaumont, TX, USA
It that is the reason for the "ERROR" message, then it may also be possible that some dirt or a small chip has become lodged in the scale's reader. Perhaps you can carefully disassemble the slide and clean the reading elements inside it. The import calipers usually have some screws under the rear label.
If it does not work, there is nothing to lose by trying to repair it.
I GOT IT!
ERROR means that the electronics are not seeing the slide. In my case it was a lot of corrosion. If your battery contacts are buggered, you'll have to do a bit fashioning new ones and a bit of soldering. After that, you can clean it up and make it work again. If you're careful and lucky.
see: https://drive.google.com/drive/folders/1AKq13Q5R0o6DNqVoMeJ6AxGFAgQXT24l?usp=sharing
Hope this helps.
OSD
