300TD4x4
- May 15, 2003
- Pollock Pines, CA, USA
I need to make or resize some valve guides so I can run larger stem valves in a Ford turbo 4 cylinder motor running 25 psi boost. I tried to drill out one of the guides and it kind of cracked apart. Don't know what material it is made from but the head from which it came was from a 99 Ranger 2.5. Is bronze a suitable material or is there something better? If itt should be bronze, what type? Where can I get some? The OD is around .490 and the ID around .340.
Brian
Brian
