Tyrone Shoelaces
- Apr 19, 2006
- Manchester, England
That bevel gear looks like it was fitted last week.
Regards Tyrone.
Regards Tyrone.
If you were working on large castings they would have been marked out before they came to the planer. I did a bit of marking out for a couple of years, I liked the job. It was interesting and you weren’t busting a gut.View attachment 371331
Havn't made a lot of progress on this project lately, but here and there I've been squeezing little bites in (how you eat an elephant and all). Since the left work head was already apart, I've been putting it through the evaporust bucket a piece at a time before putting it back together. The back of it still shows original scraping. Found some fasteners missing and have been making replacements as I can, such as these 3/4" bolts made from 1 3/8 hex stock, which seems to be the common set-up bolt head size.
Once the head is back in one piece, it'll go in storage until the planer has a roof over it again. The adjusting screws iron acme nut is pretty well stripped, but not all the way, so I took dimensions from it and will make another before or when it fails.
I noticed that none of the adjusting screws or sliding ways on this machine have any kind of incremental dials or rules, with the exception of the work heads having degrees on the side to set tilt. Is this just how old planers were, or just planers in general? Would everything just have been set with surface gages, planer gages, and shim stock (considering this was before indicators became common)?
That makes sense. So instead of relying on the machine's accuracy to move .005" for example, you relied on the guy setting it up to be able to measure it's movement via hand-tools and gauges.If you were working on large castings they would have been marked out before they came to the planer. I did a bit of marking out for a couple of years, I liked the job. It was interesting and you weren’t busting a gut.
You’d paint the relevant areas with whitening and then mark out the cut lines for the machinist with a big height gauge and a big sheet metal square. it took a lot of thinking about. You had to weigh up how much metal had to come off each face. No point taking half an inch off one face and leaving the opposite face in the black. You might have several recesses working back from one face and oiling points on the outside faces at 90 degrees that had to line up with the recesses. It could take you several goes before you got the job right. Painting out your lines and starting again etc. When you were happy everything was ok to the drawing you centre punched your lines every two inches nice and deep.
After that the machinist took over on the planer. He’d set up on the table to your lines with a big scribing block or height gauge. When the job was done you expected to be able to see the half centre punch marks. No centre punch marks and he’d ballsed up by taking too much off. Most guys worked off a DTI stuck on the planing head. Later on we had “ Trav-a-Dials “ and DRO’s.
Regards Tyrone.
I'm thinking 1/2" square or 5/8" square will be the most common and those will fit standard lantern type tool holders, but I would like to make some holders for wider bits too, but more for finishing passes then hogging metal (using the width to take a skim over a wide area). When I make the holder(s) for the bigger bits they'll be oriented behind the tool shank.1.) I can't see how much reduced the bolt is, nor determine if it is, say grade 8 equivalent, or grade 3 equiv. Weasel wording aside i much prefer to run the tool behind the shank. OTOH i made my holders and put the strength in accordingly.
2.) If all you ever run is 1/2" x 1/2" bits, you have more HP than you need. Unless maybe both heads are running a the same time, both with at least1/2" bits.....
Perhaps to more directly answer your Q, my machine has 1-3/4" drive belt (which i increased from the received 1-1/2" or maybe a little wider) and a 3HP motor. It can slip the belt in deep or wide cuts, while the motor remains un-stalled. So i get what you are talking about. Supposedly, the belts on mine should be good for 5HP or more according to the book. Not sure i've figured out how to do that.
Holders for small tools can be economical in cost and easier to grind, because not all cuts or profiles need be large just because the machine is. OTOH you can run at least 3/4" square bits on that planer, and 1" might be convenient at times. My 3 HP will run fairly heavy roughing cuts in CI with a round-edge 3/4" bit with some shear stepping over quite a bit depending on depth. Steel is a different ball game because the tool geometry is more delicate for finish, but here again, wide is helpful. While roughing, thick is helpful. So it is easy to get where 3/4" or larger bits are more efficient and more fun.
Nice to see you making so much progress!
Stephen, Does your Whitcomb have the boses pictured, or anything mounted to them? There's one inside each column and I think they're related to the on-board jack-shaft set-up pictured above, as there's a handle just below them that I think would be for engaging a clutch.1.) I can't see how much reduced the bolt is, nor determine if it is, say grade 8 equivalent, or grade 3 equiv. Weasel wording aside i much prefer to run the tool behind the shank. OTOH i made my holders and put the strength in accordingly.
Yes mine has the power rise and fall. The shaft for that is on the very top, whereas these bosses seem to have interacted with a shaft that went through the upper openings in the columns (below the red circle in the above picture). The only data I've got for this set-up is the picture in post #88, which isn't very clear, but it looks like there's a handle on the right side that perhaps would be pushed/pulled or twisted? You can also see a ring going around the jack-shaft with an array of holes. My assumption is that it was a two pulley slip clutch with the belt being moved by the handle, and the bolt circle was the shipper and allowed you to move the fingers to different angles depending on where your belt was coming from. The whole set-up seems to be marketed to shops that might not have an over-head shaft arrangement, or the machine was expected to be moved around, and in either case the jack-shaft would stay attached to the machine.On mine the bolts in that area only hold brackets for the overhead drive. The threaded holes are also not quite like yours, in that they are radial along the circumference of the curve. (rather than square/parallel to the table)
The brackets on mine are probably shop made, although professional.
But the point is, nothing interesting is/was happening up there except as points to mount the OH drive.
So realistically, you can use them for whatever is convenient.
What sort of clutch would you need?
PS: looking/thinking a bit harder - did yours have power raise/lower on the rail? ("rapids") The only thing that overhead rod is for on mine is rail height adjustment - theres a miter gear on each end to synch the acme screws on each side of the column. With a hand crank on the end as in the B&W picture you posted a little further up. Yours seems to have a pulley, which is suggestive? But i doubt it is essential to the operation of the planer to add power back to it if major parts are missing.
That's really not a bad idea, at least for the short term. A log splitter has been on my list of attachments I want to make for my Ford 8N, and I could probably get the hydraulics rounded up and plumbed first, cobble the cylinder onto the end of the table, and have a redneck hydra-plainer! If the table is moving, there's really no need for the line-shaft if I manual feed (auto feed is driven off the end of the pinion gear shaft). Wouldn't want to do it long term, but it could get those first sections of rack made. I'm already planning on using the tractor to provide flat belt power if the shop engine is down later.Hide a hydraulic pump under the bed and drive it off the gearing up to the overhead lineshaft. Install a home made hydraulic cylinder under the table. Problem solved.
I know that is not what you want to hear. A wild thought though. Easier said than accomplished.
Another thought on the gear rack. I'm sure the original was made of cast iron. You could get Windy Hill Foundry to cast blank sections of rack rather than using flat bar. Might even get the gear teeth cast, too!
Notice
