Bill D
- Apr 1, 2004
- Modesto, CA USA
Most advice I see says to start a hole in the lathe with a center drill then switch to the twist drill. For the drill press they normally say center punch then spot drill or directly to the twist drill. Do they assume a Dp owner will not even know what a center drill is?
Only using smaller drills and working up in size if the hole is large.
I did use a centerdrill to locate a start hole in my DP this morning. I only used the short nub to make a dimple not the full center portion
Bill D
Bill D
