This kind of corresponds to some of the papers I have read on scraping. They are like "grinding does not actually leave the surface flat" it apparently mounds the metal around into shallow dunes apparently, which seems kind of counter intuitive because you kind of think of grinding as a flattening process, so how is it that it fails to process flatness.
It's not actually that it mounds the surface so much, but first, that it is hard to hold something down without distorting it in some way when you use either a clamp or a magnet or what have you to pull it down to resist the forces of the table and part moving back and forth or a grinding wheel acting on the part, etc. Once you grind as flat as you can and release those clamps or the magnet, guess what happens? Also, one false move with the grinding wheel that produces a burn mark, or in other words too much heat, can warp the part. That can't happen with scraping.
Second, a surface plate used for scraping should be approaching about as flat as is humanly possible to get. Easily as flat as an extremely high quality grinder's ways will be when brand new, if not flatter. The difference is the surface plate is used gently only for comparison and if it's used for commercial scraping, is generally checked every year and corrected if necessary by lapping. Grinders not so much, and they won't maintain that flatness. A rebuild on the ways of a grinder is not so quick, easy and inexpensive as a quick check, and if necessary, lapping of a surface plate. It is more economical to grind the parts as close as capable and do a precision scrape job to finish the part to a flatter level where and if necessary. There are some things where a good grind job is close enough and some that are not.
Edit: and I mean flatness in the global sense - averaged across the entire surface. At the local level there will of course be the highs and lows due to the scraping process that hold oil. For moving surfaces these help oil spread across the entire surface immediately as soon as the surfaces move across each other. They are generally tenths or less in depth, but that's a lot deeper than "jewelling" or engine turning. There's also flaking, which is even deeper.
And yeah, alignment is another important use of scraping - didn't think to mention that one since the main gist of the OP seemed to be geared toward flatness.
