Elemental_Garage
- Jan 12, 2023
Hey all,
Running wiring for the TM2P. I'm planning to wire it to a 14-50 (I know it doesn't need neutral, but futureproofing in case something else goes there in the future). I'm getting hung up on the "ground wire must be the same size as supply wire." Does this mean I can't use 6/3 romex since the ground is slightly smaller than the supply in those? I currently have 6/3 run but can undo it and go Thhn in conduit if I need.
From the plug I was going to create a pigtail of 6/3 inside sealtight conduit and run it up the machine's backside and into the supply panel. That way it's easy to move the machine for when I have to drywall the area.
