Wood grinder teeth material spec.
I would guess that those teeth are made from a tool steel of some sort with high impact resistance. Something like S2 or S7.
being that, worst case is to hard face with a crap ton of filler that has some carbide precipitation qualities, then any old med carbon steel will work as a base as long as the customer wants it all welded all around then machined afterwards to a sharpened state.
Ideally best is forged into a shape then ground sharp in a hardened steel. most end up being A8 or S7
1045 is available as plate and can be sawn, so no HAZ.
Nobody near me with that capability.
Castle metals quoted $490 for a piece 2" x 84" of 1-1/2" 1045 cut from a drop shipped UPS to me. That's $20 a piece for material. That's not going to work.
Waiting on a quote from Alro, cutting up a drop for me, but the drop and their plate saw are in Michigan.
I've found M1044 black bar, 1-1/2" x 2" at Alro in Charlotte at $640 for a 20 ft stick, so that's $8.50 ea.
I don't have any experience of "Merchant grade" material, also called "plow steel".
I've found a comment on google that says:
"Hot rolled M1044 is a medium carbon steel used in general purpose applications when special quality is not required."
Anyone with experience of M1044 able to guide me on suitability please ?
Thanks
Bob
Definition of Merchant Quality here, from Ryerson.
file:///C:/Users/BritB/Downloads/s2684ReferenceSelectionGuidesCarbonSteelBarsFinal-1.pdf
I looked up the merchant quality steel. It seems to have a little more leeway in the recipe, like tooling plate in Al. It would not be good for something with critical welds , but would be fine for hard facing. I have run a fair bit of 1045 HR bar. It runs oversized so it will finish at size after you machine off the heavy scale. The scale is a little abrasive on end mills . Just guessing but I would say around 60% machinability .
Not for the price he's offering !!
He wants medium carbon, and he'll do hardface.
Thanks
Thanks,
That gives me some confidence,
Bob
More pics....
Two rows of these "teeth" in the grinder.
The one he gave me as a sample has cracked, but apparently they last for years with repeated hard-facing.
