Working 2B-36 Devlieg
gregfortin
Nov 20, 2016
I’ve wanted a HBM for at least 10 years. It finally happened when I found this small one in Detroit recently. It took some effort with the help of a few talented men to move it and get it wired. This in my first paying job. Shout out to this website.
Derek Smalls
Jan 6, 2014
Coventry RI
DeVliegs just move the table and have no movable spindle, right?
(such as in your hole making there)
The couple I have run, which look very similar to the one pictured, do have a spindle which moves in the z axis for drilling, boring, ect. with power or hand feed. In this respect they are very similar to a conventional HBM like a Lucas or Giddings & Lewis. The table however has very limited travel in the z axis and can only be positioned, that is to say it can not be fed by hand or power in the z axis. Not sure if all Devliegs are like this or not.
I know some (maybe all???) had a slick automatic positioning system which could be programmed to go from point to point for production work. This system was disabled on the machines I have used so I don't know any more about it than that.
johnoder
Jul 16, 2004
Houston, TX USA
Thanks Derek - I must have been thinking backwards :D
gregfortin
Nov 20, 2016
Big or small, all DeVlieg’s have the same table functions. The table(platen) move to and away from the spindle and has no feed function. The spindle (Z) moves in and out and is very precise, and allows drilling, boring work.
gbent
Mar 14, 2005
Kansas
The aspect ratio looks off, it must be an extended height column. 36" x 36" travels. Standard was 24 vertical.
DeVliegs typically have the same platen travel as spindle travel. In the case of Greg's machine 12" each. A 2B is a 2 1/2" bar machine.
Peter S
May 6, 2002
Auckland, New Zealand
I was reading brochures from 1946-48 for a 3-B and they refer to the table travel to and away from the spindle as "retraction travel", for tool changing and taking measurements. Does that mean the table travel (to and away from spindle) is not used during machining, i.e. only the spindle travel used?
gbent
Mar 14, 2005
Kansas
Peter, that is correct. The platen is only a positioning axis with no feedrate. The stop for the table on the spindle side of travel has a micrometer stop, so the position is known if machining needs to be performed with the table at some other position. As made by DeVlieg, the table position is known only when the table is brought up against the stop. A DRO fixes that problem.
gregfortin
Nov 20, 2016
My machine is a Herbert and has 36“ of vertical travel. I think this might have been an optional feature.
gbent
Mar 14, 2005
Kansas
Built in England when Detroit couldn't keep up. IIFC, all Herbert machines were 36" vertical.
gbent
Mar 14, 2005
Kansas
Peter, thanks for those ads. I am wrong about all Herbert 2B machines being 36" vertical. But I don't believe I've ever seen a 24" vertical Herbert 2B on this side of the pond.
SMM
Oct 7, 2004
St. Louis
Here are some pictures of my 2B-36 at work. The machine is so versatile. I've deck and bored engine blocks, transmission cases, rebuilt the table and carriage for a small Lucas Boring mill and recently finish a Camel Back for scraping. It gets used a few times a year and I don't know what I'd do without it. It'devleig2b-36 (1) (1024x768).jpgdevleig2b-36 (3) (1024x768).jpgdevleig2b-36 (2) (1024x768).jpgs crazy accurate and machined the Lucas table ways to within .0005. Since the table machining required the entire window of travel; it provided proof of the accuracy I suspected.
Richard King
Jul 12, 2005
Cottage Grove, MN 55016
2 weeks ago I was doing a class and some maintenance work down in Oklahoma and they had 2 Devliegs, One ad a built in rotary table and the other didn't. In the manual it told you how you pull 4 alignment pins under some round plates on the table top and pull them up and spin the table. It said on some bigger machines they had an airlift table so it would spin easier. My dad use to scrape them for Kurt Mfg and we called the a Jig Mill and we scraped them .00005"/12" and 40 PPI. They ae a horizontal Jig Bore.
gbent
Mar 14, 2005
Kansas
The way Richard describes pulling the pins to rotate the table makes me think its just a regular E table. They look built in if one doesn't know what they are seeing.
davehud
Dec 17, 2004
San Antonio, Texas
This. They're not round. Just a square positioning table that pins into the working table. They pin in place at 0-90-180-270 degrees. We used to use sine bars for in between positions and then clamp the positioning table in place. For multiple positions it was often easier to throw a standard rotary table on top of the positioning table.
