Brooklyyyn
- Mar 31, 2024
- Tristsate Area
Repair has been going fairly smoothly up to this point but I am having the hardest time with the large bull gear assembly. After a lot of struggling and making a special tool I was able to get the lock washer off and spline gear removed. But now i can't for the life of me get these bearings out of the housing. Been going at it with some blocks of wood and a sledge but I can only get them to budge a few mm(should I be using a block of steel or aluminum instead to bang these out?). I tried to force them through using a long piece of all thread and some washers and bent the damn all thread rod. I don't have an arbor press, but I do have a 20 ton hydraulic forge press but been hesitant to try to use for this purpose cause a mess up there will for sure wreck the precision sleeve and I don't want to burn $500 to replace that part.
Before I go with the high risk hydraulic press route thought I would ask the folks here if there was any other idea's on how to approach this. I got all my other ducks in a row on this rebuild but this bull gear assembly is leaving me stuck in place until I can sort this out.
