Doug W
- Sep 22, 2003
- Pacific NW
So I have a 2hp Grove right angle gear reducer, worm and wheel type that I am using for a project.
The output shaft needed to be reduced for my applications so I tore it apart to replace anything, bearings, seals, etc, that needed replacing.
The design uses a straight output shaft where the 2 tapered roller bearings and worm are simply press fitted. There is no shoulder, snap ring, cross pin, set screw or anything else to keep the shaft from walking out.
I know that there should be no axial force from a pulley, but still I find it odd.
Is this typical on lower power rated gearboxes?
There are 2 steel collar spacers for setting bearing preload, they fit loosely on the shaft. I am thinking of making another, a press fit and drilling and reaming for a tapered pin.
Or just make another shaft with a shoulder on it.
Other issue is the bearing caps use 0.010" thick gasket material. Seems to be unobtainable without buying yards and the 'ask for a quote' routine.
Thinking about reducing the spacer heights 0.010" each, deleting the gaskets and using RTV to achieve proper preload.
Any thoughts?
Any thoughts?
