idacal
- Aug 9, 2011
- new plymouth id
Im looking for a oxy propane magnetic pattern tracing cutter preferably within a few hundred miles of boise, if anyone knows of one or has one for sale. I'm needing one
I bought, repaired, and then sold one years ago.Im looking for a oxy propane magnetic pattern tracing cutter preferably within a few hundred miles of boise, if anyone knows of one or has one for sale. I'm needing one
Who says you need 1/4" steel patterns? 16 gauge works fine.Ten years ago I wanted one and started asking local shops if they had one in the back gathering dust. Second place I asked had one so I bought it. Got it working and hated it. Then I bought a Koike portable CNC torch and I use it all the time.
If you are cutting many parts with one setup it might be worth the time to make the pattern but I found it difficult at best to get any kind of accurate cut. You need a smooth accurate pattern to make a decent cut, so how do you make a circular pattern out of 1/4” steel? It is a catch 22 machine. It was not a good solution for my one-off part requirements.
Have you tried adding an oxy torch to it ?I have access to a 6 x12 plasma table but but i dont want to buy a 200 amp plasma and upgrade power supply for the few times a year I need I need to cut thick stuff. and a water jet is not in the budget nor have the space
Why can’t you rig up a holder for an oxy propane torch on the plasma machine and cut there? Way better result than a pantograph and it takes up no space.I have access to a 6 x12 plasma table but but i dont want to buy a 200 amp plasma and upgrade power supply for the few times a year I need I need to cut thick stuff. and a water jet is not in the budget nor have the space
Notice
